JurgenRoeland
- Joined
- Oct 12, 2023
- Messages
- 30
(updated after response1)
Hi, I have a small question on the connection of the VPX serial data connection to the D37 harnass.
I'm not very confident with wiring yet and feeling better safe than sorry and asking upfront to this wise community.
I read in the VPX manual that you can pick any serial pair and connect the VPX J1-21 Serial GND to any GND pin on the Dynon Skyview D37 between Pin 21 - 24.
I bought 3 conductor shielded wire and was picturing to use solder sleeve to bring J1-21 GND with shield together on the side of the D37, resulting in 1 GND wire arriving from the VPX J1-21.
this 1 GND wire would be connected to Pin 22 GND on D37
My question is, can I just use solder sleeve to to connect the vpx serial gnd + shield to Pin 22 of D37
I tried to make the question as clear as I can in the attached image
A related question is : on D37, are pin21, 22, 23, 24 GND pins internally all connected to the same GND line ?
(in other words, if connecting only the VPX J1-21 serial GND with shield in my image to IN on pin 23 and not link that further linto GND bus, does that loop through the main GND bus via pin 21 and 22 which go direct to GND bus ?
many thanks in advance.
