here's a more detailed explanation:
(Warning: this is AI generated so check the installation manual for accuracy)
More detailed, sure. Accurate, no.
Page 7-44 of revision AT of the Skyview HDX installation manual very clearly indicates that all you have to do to measure VOLTAGE at one or two locations in your electrical system (I use the cold side of the master solenoids for my two buses) is hook up pins 1 and 2 on the D37 connector to those sources and call it good. No resistors, no calibration, nada. The system understands that it's measuring voltage on those pins.
All the AI stuff above is, to put it bluntly, innacurate and not useful. If you want to use OTHER D37 pins than Dynon says should be used for measuring voltage, sure -
maybe some of that will apply, but a review of the installation manual will say for sure, and merely telling folks that they should vet what you're posting is inappropriate - don't post it if you haven't vetted it yourself.
This is just another data point indicating that using AI without vetting the output with the original source is GIGO. No one should be posting AI output without ensuring that they've vetted it for accuracy.
And with respect to the shunt and measuring current flow,
@huntaero nailed it simply and accurately.
