My d100 will not display ems data from the d180. The d100 says ems data not available Any ideas
T tbbaily New Member Joined Oct 9, 2009 Messages 9 Nov 22, 2025 #1 My d100 will not display ems data from the d180. The d100 says ems data not available Any ideas
Rhino Well-Known Member Joined Jul 20, 2009 Messages 1,785 Nov 22, 2025 #2 Which one is set as Bus Master? They can't both be set that way.
T tbbaily New Member Joined Oct 9, 2009 Messages 9 Nov 23, 2025 #3 The 180 is the master. I run flight instruments on it and engine instrument's on the f100 but everything works on the 100 except engine instruments I don’t know if the 180 isnt sending the data or if the 100 isn’t seeing it
Rhino Well-Known Member Joined Jul 20, 2009 Messages 1,785 Nov 23, 2025 #4 I meant in the DSAB network setup. If they're both set to Master, it won't work.
T tbbaily New Member Joined Oct 9, 2009 Messages 9 Nov 23, 2025 #5 Rhino said: I meant in the DSAB network setup. If they're both set to Master, it won't work. Click to expand... The 180 is setup as the master on the dsab netwtk. It’s worked for 8 years and just lately hasn’t worked. I don’t if the 100 orc180 is bad
