kurtfly
- Joined
- Jun 21, 2014
- Messages
- 320
Regarding the sending flight plan to an IFD from Foreflight when connected to Skyview network it still does not work reliably. This is a Foreflight issue. If you have more than one device that can accept a flight plan it assumes the first device it sees, Skyview. However, you can get a flight plan from an IFD to Foreflight by using the MORE, DEVICES, select the IFD, tap the displayed flight plan. It will then load into Foreflight active flight plan.
regarding the Skyview ADS-B traffic and Weather displayed on the IFD. It does not work. I Wiresharked the Skyview network and discovered that when the IFD connects to Skyview network it auto assigns the IP address 10.177.82.171. However, the ads-b traffic is UDP broadcast on IP 10.191.255.255. This is a different subnet. So, the IFD is not configuring the WiFi connection correctly ie. Subnet masking correctly.
when I connect my tablet running Foreflight to the Skyview network it auto configures the WiFi to IP: 10.191.1.1 with the Subnet Mask of 255.240.0.0. it has no problem seeing the UDP data stream.
i also configured my IFD to connect to another airplane in my hanger that has a Stratux. This works, traffic seen on the IFD. The Wireshark data shows the ADS-b data is on the main IP address. Does not use a subnet. I believe this is the problem regarding the ADS-B data. I have provided this data to Avidyne. I asked if they had a way to manually configure the network interface but they have not responded.
