How to quiet repeating alerts
jwilbur
kcjr
I Had a CHT probe go crazy on me recently. Temp jumping up to 500 then back down to zero and everywhere in between. That issue is fixed. However, when it happened, every time the temp jumped up over the programmed limit, the Dynon HDX voice said, "Cylinder head temperature". Drove me crazy for the remaining 20 minutes of the flight. Is there any way to tell the HDX to quiet an alert like this for the remainder of a flight?
Do your problem is on the cylinder n. 4...?
I have the same problem but with EGT sensor: I quieted the alarm only reducing the system volume, on the settings.
The problem is probably on the connector that tranfer the signal between the sensor and the unit: is in this direction that I am investigating...
I’ve requested this feature previously. It would serve the useful purpose of suppressing any recurring nuisance warning for the remainder of a flight.
Airbus, as an example, call this “emergency cancel“ and when you need it, you really need it! In their case it has a specific button, but my vision is for a Skyview softkey to be available while the relevant message is active.
I second the request for this soft key emergency cancel.
In my case I rerouted the CHT #1 probe wiring further away from the spark plug. The crimps seemed solid. However, if the problem comes back I'll be cutting off the crimped connectors and redoing.
One way, less than optimal admittedly, is to go into the EMS menus and remove the pin assignment for that particular probe for the remainder of the flight. I suppose you could make the alarm latching rather than self-resetting, and that should work.
But yeah...some sort of "shut the f**k up" option would be nice for failed probes like that.
That's a handy trick, which I've used when the problem was a dying probe. It gives you some peace until the faulty part can be replaced. But there are some alerts that don't come via an EMS pin, so they can't be selectively silenced this way.
My daughter, for reasons best known to herself, christened the voice "Janine".
She has become a trusted friend and assistant, and her sultry tones are a welcome means of announcing autopilot mode changes, assigned altitudes and of course the occasional caution message. But once in a while, I'd like to be able to say, "Thanks Janine, I know about that one. You don't need to keep reminding me." So far it hasn't been possible.
This is how I have dealt with it. You get 1 alarm and it holds until you clear it manually. If you think the situation is cleared then go ahead and clear the alarm and it will alarm once again. This seemed like a better solution than disabling the sensor as it allows you to still watch what it is doing without being yelled at constantly :)
