Serial Connection to XCOM 760
TheFrisco
Anyone connected the SkyView serial to an XCOM 760? Does it go both ways? What setting did you use on the SkyView, like an SL40?
Thanks Robert
If the radio uses the Garmin SL30 protocol, it should work fine. That would depend on the XCOM documentation.
No documentation around that, and don't think company still exists 🙄
Tried all protocols, no luck
Thanks Robert
So I tried pretty much every different radio choice in serial setup to no avail 😢
It allegedly behaves like a Garmin SL-40.
You may need to enable the serial interface on the XCOM radio. You can do this executing the following steps:
1. Switch the unit off by holding the ON button for 3 secs
2. Hold down the DUAL and MODE buttons and press ON
3. The unit should start and show the software version (Note the version)
4. Press the F/CH knob until RHEAD is shown
5. Turn the F/CH knob clockwise and the display should show ON
6. Press the FLIP/FLOP (double arrow) button
Once this is done the serial interface will be enabled and you can set frequency to the XCOM from your EFIS.
Did all the above, still nothing 🙄 ... RHEAD enabled, serial connected to port 1, input device setup as SL40, "Display COM in Top Bar" turned ON, can see package count go in and out, but still no tuning.
Any other ideas?
Does it work in any direction (tune radio, does it show up on the Dynon display), vs. tell Dynon to tune COM. Either of these work? If not, check your serial port connection and configuration. Maybe RX and TX are reversed?
It looks like I used a bad image online that confused me. Going to airport today and will swap the two. Wish I had tried that sooner 🤣
Switched and still doesn't work 😭
Calling Dynon tech support tomorrow, hope they have some suggestions.
Thanks Robert
DYNON TECH SUPPORT UPDATE
The XCOM serial input/output is formatted in such an usual way that they decided not to build support for it. So NO XCOM DYNON serial connection! On a positive note, their tech support rocks, called them this morning and got a call back within hours. #LoveDynon
