- Joined
- Mar 23, 2005
- Messages
- 13,226
The New SkyView
Today Dynon is excited to announce a suite of new products, along with SkyView 10 software which features over 30 new features and improvements. For more information, visit www.TheNewSkyView.com and download the new SkyView brochure.
New Products
SkyView Touch™
Today, SkyView enters a whole new era: touch. But don't worry, this is touch the Dynon way: “Touch when you want it; Turbulence when you don’t.” What started as a grammatically challenged joke of a catch-phrase turned into the philosophy that we used to guide the design of SkyView Touch™. Although we all use touch-controlled products like smartphones and tablets in our daily lives, turbulence can quickly render a touch interface practically impossible to use. SkyView Touch solves this by using touch to augment and complement the physical buttons and joystick knobs rather than replacing them outright. It’s the best of both worlds.
Elements like on-screen keyboards speed up entry of airport identifiers and the map zooms and pans just like you've experienced on every tablet you've used. Touch an airport for more information, or touch an airspace and the altitudes pop right up. Touch the altitude tape and the closest knob assigns itself to adjusting your altitude bug. Touch the transponder and up pops the transponder menu. The system retains Dynon's industry leading screens with incredible brightness and anti-glare properties, so there's nothing in the way of your flight on a bright, sunny day. The ability to automatically dim enough for even the darkest nights? That's still there too.
Not convinced? No problem. The non-touch D1000 is still available, and it isn't becoming a second-fiddle product. SkyView Touch is built on the same platform and runs the same software as non-touch products, so everyone will continue to get the same software updates in the future.
To top it all off is the price: SkyView Touch™ is priced at $3995 (MSRP), only $395 above the non-touch 10” display. Dynon’s commitment to supporting product platforms for years means that existing SkyView customers don’t get left behind: every existing SkyView SV-D1000 display can be upgraded to touch for only $795. No panel cutting or re-wiring needed: Just drop it in. SkyView Touch displays are plug 'n play drop in replacements for existing SkyView installations. SkyView Touch begins shipping in April 2014, with updates to existing units starting a bit after.
Knob control panel
SkyView was designed with maximum flexibility in mind, which is why it has 8 "soft" keys and 2 re-assignable joystick knobs. In busy cockpits, sometimes all you want is a knob that "just works" and always does what you expect. The SV-KNOB-PANEL solves that issue with three knobs for the most used functions: Altimeter setting (BARO), Heading bug, and the Altitude bug. It has quality, heavy-detent knobs, with an automatically dimming backlight for night flight. It's incredibly easy to install with simple plug-n-play integration to SkyView Network with no aircraft wiring needed. The SV-KNOB-PANEL comes in Horizontal and Vertical versions beginning April 2014 for $250.
Autopilot control panel
In the same vein as the Knob control panel, the Autopilot control panel allows full control of the SkyView approach-capable autopilot without touching a single button on the SkyView screen. Just reach up, touch the mode you want, and sit back while SkyView takes the work out of your flying. Innovative features like the LEVEL button are always there for you no matter what else you are doing with SkyView. All buttons are backlit and feature sharp tactile feedback when pressed.
It doesn't stop there. The Autopilot module is also a full featured dual axis trim controller. It can manage your electric pitch and/or roll trim motors, replacing any relay decks that may be in the airplane. It also has the ability to slow down the speed of trim as you fly faster so that your trim sensitivity is the same at all airspeeds ("speed scheduling" in jet-speak). More than a simple two speed controller, this feature is fully proportional across airspeed and can be easily adjusted right in the SkyView menus.
Controlling trim in your aircraft is serious, and we take safety here to the next level. The trim controller works even if SkyView is offline, with redundant power inputs. Trim is protected from running away due to stuck buttons. The outputs are protected from shorts, and the pilot has priority over co-pilot inputs.
Use of the trim controller is optional. The SV-AP-PANEL is available in Horizontal and Vertical versions beginning April 2014 for $550.
