What's Everybody Flying?
SV_Classic
Avionics are fun to talk about once in a while I guess but what's everybody got their Dynon stuff in?
I picked this up last May, it had Dynon Skyview Classic 7" and 10" displays in it with the comm, transponder, ads-b, ahrs, intercom, and gps antenna components. The airplane sat idle for almost nine years and the builder didn't do such a great job installing everything so I've been redoing the electrical system and going through all of the Dynon connections. It'll be ready for the engine when I get it back and will hopefully be flying again by around mid March. It's a Pitts Model 12, the last full design completed by Curtiss Pitts before his death. The engine is a Russian Vendenyev M-14P, 9 cylinders with 360 stock HP.
Cant compare with the ramp appeal of the Pitts above however, you asked;
Sonex, Legacy, Rotax 912ULS, Airmaster CS, plans built & personalised - EconoCruise 75% power (5000 engine rpm) delivers 130 knots @ 3500ft for 15L/hr ULP consumed. Fitted with Dynon Skyview SE SV/D600
Phot, before first flight,132 hrs later, unpainted cowling, much changed (for better cooling) & painted
Plans built? As in you started with sheets of aluminum? I saw an RV-4 earlier last year that was plans built, not a lot of aluminum planes being plans built anymore.
4 gal/hr at 130kts is pretty good too!
"Plans built?"
Yes, plans built.
Some component were "off the shelf" - Sonex supplied the engine frame & bed, glass wing/tail tips, main wing spar.
I would like to claim "all my own work', the truth is I purchased the aircraft in an advanced stage of completion, from the astonishing person who started the project.
He spent something like 10-12 years building, to equal certified (if not better) standard.
All aircraft grade components, down to solid rivets throughout (not a standard Sonex build).
The aircarft boasts a number of innovative feature eg 30 L wing tanks, (total usable fuel from three tanks -96L) a custom mechanical/spring elevator trim system, etc
Unfortunatly for him , he developed a neurological disorder, that made it impossible to complete the project.
It took me another 18 months, of intensive work (I am retired from paid employment) to put the aircraft in the air.
A neighbouring airfield, is the home of the first Australian RV4 - a plans build. Still flown very competently by the builder (he has barrel & aileron rolled it, with me in the back seat). It's a work of art - still looks like it has just come off the showroom floor. 😈
Original build: Vans RV-9A.
Second build: Harmon Rocket.
Current build, with 5 hrs flight time: Rans S-21.
All Dynon based…. D10A….SkyView…SkyView HDX.
The panel photo shows a set of discrete flight instrument that interwork with the SkyView system, including an OnSpeed energy display and a tailBeaconX transponder controller.
And yes, there is a horn!
Nice little EuroFOX with Rotax 912iS.
RV-8. Finished it in 2011 and have flown it for 1423 hours. Original panel, which I wired and installed, was a once and done for me. When it was time to upgrade the panel I went with a Skyview Advanced Panel. Love the ACM!
My Covid "sanity project" was started in March 2020 and Airworthiness earned in August 2023. First airplane build is a Vans RV-9A and it’s a joy to fly. Dual Dynon HDX and now starting IFR rating at 63 years old.
Velocity and Long EZ. System very stable, no issues!
Bearhawk Scratch built Dynon Avionics EFIS SkyView Classic system with single PFD, dual com, Mode S transponder, ADSB, 2 place intercom, knob control, 2 axis A/P, moving map and engine monitor, Dynon Remote magnetometer SV-MAG-236, Dynon EFIS SV-Bat-320 back up battery. I-pad flush mounted Mimi I-pad with Garmin USB power supply, Airpath C2400 L4P wet compass, ACK E-04 406 ELT coupled to GPS.
2021 Oline ErgoPro. Airspeed: 0. Climb rate: 0 Ramp weight: 48 pounds. Useful load: 300 pounds. Crew: 1. Passengers: 0. Fuel flow @ cruise: 0 GPH. Service ceiling: Unlimited.
Had a few health challenges lately. Eight surgeries last year, and a few more to go. This is all I'm flying for now. Pay no attention to the trash can.
20+ years as a Dynon beta tester.
Absolutely LOVE Dynon products!
This is my Van's RV-9. I performed some upgrades in the spring and took the panel picture before the labels were applied. (Added a Garmin 175, ToGa button, heated pitot, and alternate static source.)
I've got a few different aircraft, but just finished the install in my 1954 Cessna 180. Took about 3 weeks.
Where are you located, and would you like to do an install on a Cessna 170A?
Alaska. My 170B is actually next in line. They're pretty straight forward, most A&P's should be able to get you sorted. I don't really do other people's projects.
AK is a long way from SC via 170. We need to find someone local.
Thanks!
Used to ride an RV-8, then after flying a comfortable but boring C-177 for a while, I came to my senses and bought a fun to fly Wilga 35a, but my current ride is this:
Just saved it from 9 years sitting in a hangar. After weeks of restoring and upgrading and overhauling, it finally flew again !
RV-7, dual HDX and SDS EFI. 12 years building, wired it all myself with a sweet interconnect board provided by the dealer I bought the system from.
Looks like I'll still be flying my chair for a while. Eight surgeries last year, and they've just scheduled me for another one. I may end up being permanently grounded.
