172M Panel Upgrade
Lynden, WA
I'm going to have Six Pack Aero replace the factory original control yokes with new ones from Cessna.
The new Cessna yokes are a better fit when compared to the originals.
They'll easily bolt into place with the new shaft-to-yoke adapters (a separate Cessna part number).
I strongly considered the Avion Research yokes, but I'm of the opinion that they're too big for a 172 flight deck.
They'd look fine in a 182.
They're too heavy and they look out-of-scale when fashioned in front of the instrument panel.
An Avion Research yoke weighs 2.7 pounds. The new Cessna yoke and adapter tipped the scale at 1.7 pounds.
Certainly, the new Cessna yokes will enhance the new panel!
benapilot
Thanks for posting, Bryant.
I'm in the planning stages of my HDX install for my 182 and love seeing how others are getting it done.
Keep the updates coming!!
Lynden, WA
Six Pack Aero is in the process of installing the roll servo in the left wing and
complying with the Roll Servo Cable Guard Service Bulletin that was released
on March 24th.
The roll servo isn't 100 percent installed yet, so the control cables are loose in
these images.
Scope out that cool Snap-on Tools LED lamp that's on the underneath side of
the left wing. I gotta get one of those units!
WIP.
Lynden, WA
More progress...
The magnetometer and Dynon GPS antenna have been mounted.
Wire harnessing in the wings are installed and secured, as well as wing tip strobe and nav light wiring.
Wiring for the pitch servo has been routed and installed under the floor.
The engine management system wiring has been routed into the engine bay and connections are in progress.
Stay tuned for more action!
Lynden, WA
I just had to pay a visit to Six Pack Aero this afternoon to visit N22230...
The 172 Roll Servo Guard Service Bulletin has been complied with.
The pitch servo assembly will soon be attached to the belly of the airframe with AN hardware.
I forgot to snap a picture of all of the new wiring harnessing that have been routed to the instrument panel area.
Maybe, I will visit the shop in a couple of days!
Make sure the roll servo bridle cable clamps are torqued correctly - the torque specs have been changed from the original documentation. I had "another" shop do the install on mine, and they hosed it up.
Lynden, WA
Thank you for the heads up about this issue, for that is appreciated. I'll chat with the shop about the torque value that is applied to those clamps.
Lynden, WA
The fuel transducer was installed today, as well as the manifold pressure (vacuum) line.
AN hardware was applied to the pitch servo, so it's now secure in place.
The elevator cables will be re-tensioned tomorrow.
Yippee!
Lynden, WA
Six Pack Aero is making progress with wiring up some of the components for the new panel.
It’s a work in progress…
Lynden, WA
Great progress to report on interfacing the Dynon SkyView HDX, the Avidyne,
IFD440, the PS Engineering PMA8000G, and one Dynon control panel.
benapilot
One the mounting tray, I see the EMS, ADAHRS, ARINC modules stacked. On the left I’m assuming the ADSB IN module?
Great idea with a network hub on the side of the radio tray.
What’s the connector in front of of it (pic 3)?
I can’t quite make out the brand of the avionics mounting rails…. Radiorax? I’m considering using their system when I do my panel.
Thanks again for posting!
Lynden, WA
Full disclosure: I lack the training, skill sets, and experience to answer your
avionics/electrical questions.
It's probably best that you contacted Six Pack Aero, and had them clarify
your questions.
I'm sure that they would be glad to help you in any way they could. They're
very friendly!
I believe that is the ADS-B In module on the left, but I'm not 100 percent certain.
Here's the link for that component on Dynon's website. Hope this helps.
The same circumstances for the connector that you reference. I am not sure of
what is connected to it. Six Pack Aero would have the answer to that question.
I'm sure if you reached out to them, they would be happy to answer your questions.
Here's their contact link.
On the left of the Dynon tray is the SV-ADSB-472.
That's a Radiorax mount system. Not sure about the connector.
Lynden, WA
A visit today at the Six Pack Aero hangar revealed more great work in progress!
Lynden, WA
A visit today at Six Pack Aero revealed that the wiring has been completed for
the push/pull circuit breakers and control switches.
Scope out those copper buss bars!
Caution with the copper bus bars, make sure they are covered with something during install, or inaccessible from your seat. I ruined a new stainless steel coffee cup one day in my RV by letting it slip under the edge of the instrument panel and short the panel to a bus bar, notched a spot in the lower edge of the panel and took a chunk out of my coffee cup! Fortunately that was the extent of the damage, but it had my attention!
Lynden, WA
Thank you for the heads-up about this issue. I'll keep the panel area free of any stainless steel coffee mugs!
