- Joined
- Oct 6, 2010
- Messages
- 1,712
If its going to be a while before I get a replacement 472 for my 470, does Dynon have a dummy 472 box I can get so I can move ahead with my build? I have to change or re-build the antenna cable and dSub connector and it would be nice to have a box to mount and connect to while waiting....even a returned early 472 would help.
The connection to the 470 is the same as the 472, based on prior Dynon responses to the question. Only the mount holes will change. The mount hole pattern is shown in the installation manual, page 1404 of the AD revision.
Sorry to differ, but the 470 dSub and antenna connection are on one side and the 472 has those connections on two different sides. Envision this. Hold the 470 with the dSub and the antenna in the down orientation. In the same orientation, the 472 connections would be: dSub to the left and and the antenna connection to the right.
Also, the 470 "box" dimensions are approximately 7" x 4.5" x 1.1" in outside dimensions. The 472 is is approximately 2.79" x 4.10" x .97" in outside dimensions.
This is hardly a catastrophe. Unless you didn't make your harness with any service loop, I guess.
