EGT & CHT probe failures
Has anyone else experienced excessive EGT/CHT probe failures? We have had our HDX system for just under a year (135 hours) and I’ve already had to replace 2 EGT and CHT probes, then this morning one of the new EGT probes is failing again. They are easy enough to replace, but the failure rate seems excessive. I’m wondering if there is something else I should be looking at.
Failure mode is that the reading jumps all over the place and eventually X’s out, generally within the next flight or two.
Good morning everyone. I wanted to comment on these threads for some time but haven’t had the time. I too had a huge reliability issue with the Dynon EGT probes and was replacing at least one every oil change cycle. After replacing all 4 cylinder probes at least 4 times I said enough. Looking at the aircraft spruce cost of Dynon probes verses JPI probes, it kind of made sense… half the price for half the service (kind of like AT&T). My probes always failed open. Tried to open up the probe but could never determine why, I do know it wasn’t the connector or its crimp. I replaced all 4 with JPI probes and have improved my reliability numbers to what I would expect from a JPI product. Even the Dynon rep at Sun N Fun 2024 suggested I use JPI instead. Who’d a thought…🤔
I had two of these garbage Dynon EGT probes fail on me yesterday at the same time. Yes the same time (as I pulled in front of my hangar) and yes I've checked them out with a meter, swapping probes with good ones, etc. They're just bad. And here's the topper, they only have about 2 hours on them. I just flew the plane for the first time on November 10th. What awful quality. I won't buy any Dynon probes in the future. Glad to see that there's another choice with JPI
I have used EGT sensors from The Sensor Connection from original installation. They last around 800hrs and even then could probably be cleaned but I just put new ones in. The will also make the leads any length required. I use 24" and just ordered 4 last week. Price was 277 total delivered.
We are in the process of stocking a different EGT probe offering from Tempest/Alcor as a premium option for customers. Once we have adequate stock on hand, we'll be able to sell them to those who wish to use a different type from us. The main goal is to improve on the quality and reliability that our customers expect out of these engine probes.
They must be a bad batch. I have 700 hours on mine with no problems.
Or …. Some are using poor quality connectors/incorrect crimping tool etc. I’ve replaced 2x EGTs in ~ 2200 hrs!!! Btw the CHT probes usually ‘fail’ due installer induced ie bending them too far/ much or as above - all IMO of course.😉
Five years on my HDX system, six cylinder IO-520 - only replaced one probe and that was I routed it too close to an exhaust header and burned thru the insulation!
There’s a saying “a bad ‘Tradesman’ always blames his tools” - I am guilty of that too, however I’m a fast learner &, since a couple of meltdown episodes (just could not believe it was my fault), I found that working life has been a lot easier after I came to terms with that.
This whole EGT probes/connector episode reminds me of how NOT to react to a problem.
Smart people confess & slap themselves a bit or say “my bad” when they do make a mistake - then move on.
Over the years since ~ 2005 I’ve written several “posts”, mostly on this forum or VAF, based on my experience with mainly the Dynon supplied thermocouple probes & wiring.
Around that time the thermocouple wire, in the supplied looms & probes were a single conductor wire (24 awg ?) which caused all sorts of issues/ connector ‘failures’.
There was a ‘fix’ for that however sometime later the supplied by Dynon probes/loom then had multi strands to better ‘fill’ the connectors enabling more crimping force.
However, yes, there continued to be ‘pushback” by many who said they still had ‘probe’ problems - there is sufficient evidence refuting that IMO.
Using a single jawed crimper &/or using the (dark red insulated) supplied spade connectors are the MAIN cause of reported problems by many.
As an added precaution I always now, & have for the last few years, use a good electrical contact cleaner (pressure pack). Remember we’re measuring millivolts here so contact cleaner is my weapon of choice.
For a few years now I’ve been using the PIDG spade connectors with a double jawed crimper (~ $55) without any ‘issues’.
Also the 2 pin Thermocouple connectors & the OLC type are good too - pick your ‘weapon’ .
Please, please be mindful of your criticism of various manufacturers products - you just may be the culprit 🤫. Jake
Definitely correct. The connection from the thermocouple wire to the wire running back to the EMS is the weakest link in that chain.
