I love aviation!
Have you run a test on the P1 screen backup battery ?
I find that great strategy.We've heard rare reports of this - a small handful in thousands of installs. Are you saying that you aren't even able to connect to the SkyView Wi-Fi access point? One thought - try constraining your system down to one display by powering the other down. You'll then need to do a network configuration so that that display thinks that it's the only one in the system. Then, make sure Wi-Fi is still showing online in SkyView setup. Does that change the behavior? Rinse, repeat with the other display. Basically, we're looking to see if the performance issue is tied to one of the dongles (and if it seems to be, swap the dongles in the displays to confirm that it's the dongles and not somehow the displays)
What brand of Wi-Fi dongle have you been using?So I have now ordered a replacement Wi-fi dongle and we will see what happens....
What brand did you just order?
Good.An update..
Well I have now changed both genuine Dynon Wifi dongles with like for like new ones.
Having done 3 flights now I can say that everything is working perfectly. Changes from 'Waiting for Skyview' to 'Send to Skyview' on Pocketfms Easyvfr happen straight away and all is good.
