Skyview Wish List
JPSchultz
I just completed the stall/AOA calibrations for the 4 different flap settings on my RV-14A. I was surprised to then find out Skyview doesn't record or display the airspeed where each stall occurred.
I wish Skyview would indicate the stall airspeed values for each flap setting (Vs, Vs1, Vs2, Vso) on the airspeed indicator tape as it does for the Vx, Vy & Va performance speeds. Having these real-world numbers would create a great reference I could then add to my POH.
Your stall speed varies with gross weight (and associated g loading), rate of change of airspeed, center of gravity, and prop wash over the wing (i.e. power). The speed you stalled your airplane is unique to those factors. To calculate your true stall speed, you need to use a different method than the one used to calibrate the AoA (refer to EAA Flight Test Cards).
I am curious about what 4 flap settings you programmed on your 14. I only programmed full up, half flap (approach and shortfield takeoff) and full flap (landing).
andresmith76
I do understand how stall speed is affected by all the factors you mention. What I am asking is the Dynon software record the speed at which each stall occurred following the on-screen instructions.
I calibrated my RV-14A's stalls at 4 different flaps settings - 0°, 10°, 20° & 30°.
r2brou2
I'd also like to see the auto pilot status bar move with the PFD when that is moved to the right half of the screen instead of staying over the map page.
BradThePilot
CPDLC!!
Controller-Pilot Data Link Connection - the ability to "text" ATC messaging back and forth instead of tying up the frequency. This is the way forward!
With how often it *doesn't* work and with the required subscription...no thanks.
At this point, I'd be happy if they just stopped breaking things with each update i.e. map info items are gone as of 17.4.
cbailey
Bringing this subject up again.
We all have been listing to the wish list for a while now. Am I the only one not seeing any movement from Dynon? Yes there was an update late last year, but did any of us really benefit from that update?
Avidyne is about to release 10.3.2.2 for the IFD navigators. Some good stuff being added, not much for Dynon users. I thought this was an interesting added feature.
  • Added support for Aspen display of Enroute VNAV
Why can't Dynon work with Avidyne to so the same. I have talked with Avidyne at AirVenture, the last 2 years about this subject and the response I get every time is Dynon has not asked. When I ask Dynon why not, I got a snippy comment from a young marketing rep saying it is not important to Dynon. Really!
Enroute VNAV is an important tool, and increase Flight Safety by reducing pilot work load. I agree, also makes pilots lazier, but it is a tool that is provided by the IFD just not displayed on Dynon. I have a G5 as a back up ADI which displays the Enroute VNAV guidance.
As a Technical Advisor for my EAA Chapter, when I get asked which avionics system to install I then ask what is the mission. If the plan is to fly only VFR then Dynon for sure. But if the mission is for a very capable IFR aircraft then go with Garmin. There are a lot of great ideas on this thread, Dynon can do so much more if they really want to.
Just my thoughts
Avee8or
My only request would be integration with Garmin Pilot via USB Bluetooth module similar to the WiFi adapter currently being offered. I am sure I will receive some slack for this post, but I have never been a fan of ForeFlight. They have just added way too many features over the years without a logical GUI interface... the home menu with simple, logical Iconology in Garmin Pilot is just easier for me. I also prefer the VFR versus IFR cost structure that Garmin Pilot offers, while still retaining a full functioning Synthetic Vision backup AHRS for $100 yearly. Anyhow, I know a lot of you are anti-Garmin, and I understand this would require a GP and Dynon collaboration... but this or at least a GDL-50 ADS-B interface to display traffic and weather output on the Skyview Classic would make my day.
I agree! I keep gdl52 and garmin pilot on ipad running…redundancy.
BradThePilot
I've had the same conversation with Avidyne regarding enroute VNAV - it's squarely in Dynon's court and has been for some time. I've come to believe Dynon is in a life support mode, maintaining the existing product line as best they can. I also believe they are no longer capable of developing much in the way of new products, most likely because they've lost the bulk of their engineering team. Purely speculation, but it's consistent with their product development and bug fixing pace.
Hummel
I don‘t know if any Dynon staff monitors this forum, but I have a suggestion for the autotrim! Apparently the autotrim trims when a „trim nose up“ or „trim nose down“ suggestion appears. But the HDX has all the details to trim in a much finer granularity to zero force.
in the first picture there is an actual force and our aircraft holds the attitude by force on the autopilot servo, which ends up in a little oscillation. The aircraft is „in trim“, there is no trim advice, even though a trim force is present.
in the second picture I manually trimmed until there was no force present. This should be the job of the autotrim…
my suggestion is to use the trim force and not the trim advice for the autotrim…
thanks for considering
fabian
bspatz
GNV
Please provide a visual depiction of winds aloft on the map screen with a knob selecting altitudes. The data is already present in the FIS-B received...just not visually depicted on the map with other FIS-B data. This is a typical feature and greatly aids in-flight selection/optimization of cruise altitudes. Thanks, and Blue Skies!
